MY GUNITE KEEPS WEEPING. I KNOW IT'S A COMMON ISSUE BUT MY BUILDER WANTS TO WAIT IT OUT. HELP!!!
DROC85
6
NORTH TEXAS
I STARTED BUILDING MY POOL 1/28/20 WITH HOPES OF HAVING IT READY FOR SUMMER. SUMMER IS HERE WE STILL ARE NOT PLASTERED. THE GUNITE KEEPS LEAKING FROM A FEW SPOTS. THE ONLY THING THE BUILDER HAS SAID IS THAT IT TAKES TIME FOR IT TO DRY UP. WE HAVE HALOGEN LAMPS RUNNING AROUND THE CLOCK FOR THE LAST 10 DAYS AT MY EXPENSE HOPING TO SPEED UP THE DRYING. PLASTER IS SCHEDULED AS A MAYBE FOR WED HOWEVER THERE IS A 40% CHANCE OF RAIN TOMORROW. ANYONE HAVE ANY IDEAS? THANKS
DAVID
Jimrahbe
17,895
Bedford, TX
David,
A good plaster company will not plaster a pool if it is weeping too badly..
I had the same basic problem and it caused about a 3 month delay as the pool company tried every trick in the book to fix the problem.
In my case, the pool was in the middle of a little underground spring. Eventually, the pool company realized that you can't stop water, you must give it a place to go. They had to remove decking on two sides of the pool and install 18" wide, 6' deep french drains to collect the water and funnel it into a 8 foot deep pit with a sump pump to move the water away from the pool.. Water flows into the pump even in the middle of the summer's hottest day. In my case the pool would have never "dried up".
DROC85
6
NORTH TEXAS
CROSSING FINGERS WE WILL HAVE PLASTER THIS SATURDAY. 12 DAYS OF NO RAIN AND HEAT LAMPS RUNNING AROUND THE CLOCK(AT MY EXPENSE) HOPEFULLY WILL DO THE TRICK. I HAVE SUGGESTED DIGGING THE TRENCH IN NEAR THE TROUBLE AREA AND INSTALLING A PUMP BUT RIVERBEND DOES NOT THINK WE ARE ANYWHERE NEAR THAT. IVE GOT 3 FRENCH DRAINS ON MY PROPERTY BUT THE PROBLEM IS I LIVE AT THE END OF A RETAINING WALL ON THE SLOPE. SO WATER NATURALLY WILL COME MY WAY. UNFORTUNATELY THE GRADING IS TERRIBLE IN MY NEIGHBORHOOD AND MOST OF MY NEIGHBORS DO NOT HAVE FRENCH DRAINS INSTALLED. SINCE MOST BUILDERS THERE WON'T INSTALL AT THE TIME OF THE BUILD PEOPLE HAVE TO WAIT UNTIL THE 1 YEAR WARRANTY PERIOD KICKS IN AND THERE HAS TO BE STANDING WATER FOR IT TO MERIT AN INSTALL ON THE BUILDERS DIME. FROM NOW UNTIL SATURDAY I WAS THINKING OF BLOW TORCHING SOME OF THE TROUBLE AREAS, HAS ANYONE TRIED THAT?
JamesW
19,356
The builder should have done something to manage the ground water from the beginning.
At what depth did they first hit water when they started digging the hole?
Besides weeping, the pool can float if the ground water is high enough.
DROC85
6
NORTH TEXAS
Great question but truthfully, I do not have the answer to that. I will ask the builder. I thought from beginning that the drainage in my yard combined with the retaining wall would be cause for concern and here we are concerned. Hopefully plaster occurs this Saturday.
JamesW
19,356
You can have issues with the plaster if the walls are weeping because the plaster can get too wet where the weeping is occurring.
In my opinion, something should be done to manage the ground water.
DROC85
6
NORTH TEXAS
Agreed, the problem will present itself come Saturday if the plaster does not stick. Also I have been told that once I do my landscaping it will help draw that water as well.
JamesW
19,356
This is the important information.
Trying to "dry up" the weeping makes no sense as long as the water in the ground is going to be there.
JJ_Tex
1,170
Prosper, TX (DFW)
Do you have pictures? While we had a very rainy spring, its has been 85-90+ for the last week with no rain. It seems like there could be something else going on.
