My first solo test... results and question
dezufnoC
5
Montreal, QC
Pentair Intellichlor IC-40
Hey peeps,
Just got my Taylor K-C and performed my first test after relying on neighborhood pool store for the first month.
Temp...-> 89 degrees
FC...-->6.0
TA...-->80
CYA...->30 (low)
pH...-> 7.8
CH...->225
SALT..->3600
Assuming the CYA is low because my pool has all sun and no shade for like 80% of the day.
So I was told when pool was finished to use a chlorine tablet in skimmer along with the SWG but this does not make sense to me. Any reason why this would be acceptable?
mknauss
44,923
Laughlin, NV
Fiberglass
The CYA is low because you have not added it to the pool. In your climate, add another 20-30 ppm using the sock method. Maintain FC in target range for your expected CYA level after adding.
There is no reason to put a puck in the skimmer. It is actually quite damaging unless you run the pump 24/7..
dezufnoC
5
Montreal, QC
SOCK method and more reading... Got it Marty....thx. I do run my pump 24/7 though (in low speed) also as per instructions from pool builder.
