My chemistry cheat sheet - please critique
Griffin_pak
13
FL
I have a saltwater 17K pool with a Jandy epump + 50sqft DE filter + chlorine generator
Pool is in Central Florida.
Need to purchase:
Salt - to replenish, due to rain diluting my water
Stabilizer - to replenish, due to rain diluting my water and CYA breaking down
Alkalinity raiser - not sure why my alk decreases?
Calcium hardness raiser - not sure why my this keeps dropping?
Acid - to replenish, due to rain increasing my pH (is acid rain no longer a thing)
Texas Splash
- The TA falls over time with each dose of acid applied to control your pH
- The CH falls when you lose water to heavy rains resulting in water exchange
- Rain effecting pH.... perhaps, depending on the intensity and duration. Your SWG can also contribute to the pH creeping-up (aeration).
Reactions: Griffin_pak
ajw22
12,719
Northern NJ
You lose calcium, salt, and stabilizer all for the same reason when you lose water out an overflow drain.
Please create your signature with details of your pool and equipment and we may see other things to discuss about your pH rise.
Exlonghorn
75
Houston
On the rising pH, one thing you may want to do is to add borates (20 Mule Team Borax or PoolProof). I had excellent results in stabilizing my pH after I added borates when I installed a SWCG a couple months ago. Haven't seen my pH move even 0.1 since mid-November.
Quickly rising pH and high CC after installing SWCG
Another SWCG journey!
I recommend a good Salt Water test kit
Taylor K-1766 Salt Test Kit
I see you upgraded to the Jandy ePump. Good deal...just did that myself.
If you aren't using the PoolMath app, I suggest you do that. It accounts for the interaction effects when you add various chemicals (like when you add Borax to stabilize pH, you will also need to add muriatic acid since the Borax will also raise TA).
Griffin_pak
13
FL
Changed my signature to reflect what I have.
Got the TFP test kit + k-1766 + speedstir.
How often should I test the water in the summer vs winter?
mknauss
23,305
Laughlin, NV
It is not a bad idea to supply shade to your pool equipment. Especially any of the electronics (automation panels, VS pump controllers, etc). There are lots of ideas posted on the forum. Do a search.
carnivalday
331
Ocala, FL
That was something that never occurred to me when I had my new pool put in.....along with a lot of things that never occurred to me, but thats another story.....and fortunately my pump and controls were put on the east side of my house, so I hope with the sun on it for only a small portion of the day will give it a longer shelf life.
