Muriatic Acid
Fun4Life67
20
Mount Pleasant NC
I just put my chlorine in. My ph was 110. I need it to come down to 70. I need to add muriatic acid. How long should i wait after putting in chlorine to put in muriatic acid? I have ph down. Its dry. I need to mix 24 oz in a bucket of water.
Richard320
23,870
San Dimas, CA (LA County)
There's nothing inherently wrong with 110 TA unless you have high CH and are in imminent danger of Calcium Scale. If the pH needs adjusting, then go ahead and add the acid, fifteen minutes or so after the chlorine. If pH is in range, just wait. The TA won't hurt anything and when you do need to lower pH you'll also lower TA some.
