Multi-port valve plumbing w/ DE filter
Bugman1401
66
Charlotte, NC
Anyone have a diagram that shows how a multi-port valve should be plumbed to a DE filter?
I recently got my pool renovated with a new liner, MP valve, heater and pump. I kept my old Ever-flo stainless steel DE filter and had the contractor install it.
Now, all the DE is on the inside of the grids.
Also, not familiar with the guts of a MP valve. Is there an adjustment that can be made there or do I need to re-plumb?
Texas Splash
43,932
Fiberglass
CircuPool RJ-45 Plus
No adjustments in the MPV. The key diverter or spider gasket is made-to-fit and designed to channel water when the handle is moved. If a key diverter or gasket ever go bad, you generally replace that part only if possible.
Not sure I'm following the DE question though. Your plumbing looks correct externally to the filter, but you are still concerned about the way DE is circulating inside the filter through teh grids? The techs who did your work didn't change anything inside the filter did they? Probably just new bulkhead/adapter fittings for the MPV?
Bugman1401
66
Charlotte, NC
Nothing inside the filter changed. And, there is only one way the MP valve mounts to it. So, the plumbing to and from the MP valve is what determines the proper flow direction across the grids when the MP valve is in the FILTER position. The external plumbing is not correct in the pic above.
JamesW
36,580
DE on the left, sand on the right.
The sand sightglass is on the inside facing the filter.
The DE sightglass is away from the filter.
The DE multiport is 261152.
Pentair - 261152 Multiport Valve Kit 2" for FNS, FNS Plus Filters
Reactions: Texas Splash
JamesW
36,580
This is the sand multiport, which is what it looks like you have.
Notice the sight glass on the inside like yours is.
The Pentair 261055 Side Mount Multiport Valve works with Pentair Triton Series sand filters.
