Multi port valve identification help...
davidhum66
24
Austin, TX
Hi - I’m helping repair my elderly parents leaking multiport. Water is coming up below the handle in filter mode and in backwash. I think I’ve identified the need to remove and replace the o-ring on the handle shaft. I may also go ahead and replace the spider gasket, but seems that is fine. Can you just remove the handle and shaft or do you have to remove whole top assembly for access to the o ring? They had a company replace the DE filter, multiport, and pump 3 yrs ago. So I was surprised to see this “Pac Fab” listed on the multiport as my understanding was Pentair changed to their name many years ago. In any event, any help on identifying which multiport they have based on the attached photo (or where I can locate part #) so I can order correct parts to fix? Thanks in advance.
JamesW
21,105
The multiport has an 8-98 on it which is probably the date of manufacturing.
If it was replaced 3 years ago, it would say Pentair, not PacFab.
Are you sure that the filter and multiport were replaced?
Do you have a picture of the filter label and date code?
Do you have a picture of the whole system?
Bama Rambler
24,167
Pat has the part number correct and he's also right about having to remove the top to get to the shaft seal (o-ring).
And of course JamesW is right that it was mfg in 8/98.
davidhum66
24
Austin, TX
Thank you all for the feedback. My thoughts were the same. I definitely noticed a new multiport, filter, and pump as they were/are much whiter than the older yellowish color of the old MPV. So was surprised with the pac fab reference. Will take pic of whole system this weekend and look closer for date of filter. I did take a photo of filter previously (attached) given their old DE was a smaller unit and this one is much larger (higher). Notice also it says manufactured by PAC Fab and not Pentair. ?. Hmmm....wonder if this is old inventory that was just passed on to my parents when they replaced? They didn’t use a high volume pool builder and just used the maintenance firm who cleans their pool. I did notice it seemed to be new and in good condition when I did first backwash and filter breakdown for them several yrs ago. But still, kind of irked if they got equipment manufactured in ‘98. Pool was built in 2000 so think they got about 16yrs with old Nautilus DE filter. Thanks for confirming need to pull top assembly off to get to that o-ring. Dang - thought that would be a simple fix. But should still be a pretty straight forward repair. Will order that part and get to work. Many thanks again folks!
JamesW
21,105
Definitely odd that they got such old equipment. Maybe someone had some new old stock that they found in a warehouse?
You can see the date code punched out on the filter label at the bottom.
I don't think that the Pac-Fab label was used past 2000.
