Moving up to 1 1/2 inch
Wobblerlorri
This fall I'm planning to upgrade to 1 1/2 inch flexible pvc on my new pump and filter. I have the fittings for the pool, but not sure what I need to connect everything to the pump and sand filter. Can I get a list of bits and bobs I'll need for this project?
ajw22
22,203
Northern NJ
Pentair Intellichlor IC-60
Post pics of the equipment you need to connect to.
Chasarms
347
Dardenne Prairie, MO
You’ll need 1.5” slip fittings that are threaded to match the filter and pump.
If I were doing it, I’d add buttress unions so you can just unscrew them and take your pump in for winter. I would also consider valves at the end of the lines so you can isolate the pump and filter from water from the pool in case you need to service the equipment with the pool full.
Wobblerlorri
Buttress unions? I have some gate valves already that are 1 1/2 inch. Is this what you're talking about?
ajw22
22,203
Northern NJ
Is this what you are getting - 12" Blue Torrent Sand Shark sand filter, The Mean Green Machine 0.5 hp pump?
I went searching for information about the Mean Green Machine 0.5 hp pump and found nothing. You have a link to an installation manual?
Chasarms
347
