Motorized valves connected to same driver?
JamesW
18,510
I'm not sure that it's a good idea to put 2 valves on a single terminal. The terminal isn't rated to deliver that much power.
I would probably use the 24 volt ac output to trigger a single pole double throw relay that powers all 3 valves at the same time using an external 24 volt ac transformer as the power source.
I would put an inline fuse on each valve.
