Motor cleanup
Soundy
23
Abbotsford, BC
My Century Centurion B852 started sounding like a Skrillex track thanks to a failing bearing, so I've got it open up replace the bearings, and found some surface rust on the armature and winding poles. Any tips to cleaning this up safely? Just a gentle dressing with super-fine sandpaper? Any suggestions for helping prevent future rust?
JamesW
19,361
Not sure what would be best.
Maybe some rust remover product if you can keep it out of the wires.
Sandpaper or a wire brush might work.
However, metal dust generated might cause issues if it gets in the wrong place.
The amount of corrosion is excessive, indicating a harsh environment of excessive moisture and/or chemical vapor like chlorine or acid.
Reactions: Texas Splash
wireform
In The Industry
Aug 15, 2017
1,304
Spring Valley, NY
I would throw it up on the lathe and use sand paper. Anything chemically will find a hiding spot and come back later to haunt you. The dust with a good air compressor and nozzle will be history in short order. That bearing in the windings picture needs attention.
Soundy
23
Abbotsford, BC
That's the shim, the bearing itself at that end is good.
It's the bearing at the pump end that's toast, and surprise surprise, the seal was on the way out too - pretty good chemical buildup dripping down the inside of it.
PointeTaken
85
Hoover, AL
I’ve never cleaned the armature but I had an old pump that had some corrosion and surface rust on the shaft, and I happened to have some extra fine emery cloth on hand...it had the metal looking good as new and it remained that way for the rest of the motor’s service life.
