- Nov 7, 2018
- 1,049
- Plaster
- CircuPool RJ-60 Plus
I am in the process of constructing a new pool fence to keep our dogs out. Long story short, I have devised a way to use the 24" high landscape fencing pieces to do so. The only issue that I am stuck on is the best way to cut off the "legs" of the portion that would normally but pushed into the ground. They are made of metal, but are hollow....so shouldn't be tough. Only downside is there are A LOT of them, so I would like to use something that would be quick/efficient but not distort the cut too much. I am not sure if that makes sense. I have considered using a bolt cutter, but not sure if that would give a "crimped" look where I cut it. So, what would the good users of TFP use? Thanks!! Oh...here is what they look like.
