Missing Pebble Sheen Blue Granite near tile
dogman
Active member
May 8, 2014
38
missouri
I noticed that my pool is missing a thin strip of the pebbletec finish at the tile line. can this just be caulked, and if so, any recommendation as to type of caulk. I suspect that the water flow was pushing my acid in the same spot over and over and maybe just got too much in this area. its like a couple inches long by maybe 1-2 cm in width if that makes sense.
thanks
ajw22
18,064
Northern NJ
I don't know why you got a bit of erosion on the surface of the PebbleTec but it looks like you have plenty of plaster still on that area.
I would not try and fix it. Anything you do will look worse and may not adhere properly.
