Metal Stain on Liner
Suzanne81571
15
Eastern PA
So... I have these yellowish-greenish stains on my vinyl liner. I just rubbed a Vitamin C tab on it and the stain came off. What is the next step? Do I need to rub Vitamin C tabs all over my liner by hand or is there something I can add to my water> The stain is on the entire liner. Some areas are darker than others. My pool is a very small 12 x 24 IG.
Why did this staining happen and how do I prevent it from occurring again?
We installed a new Hayward Super Pump and changed the sand at the beginning of the summer. Those are the only two things that have changed. The pool is 8 years old. We have never changed the pump or sand prior to this summer.
Thanks in advance,
Suzanne
Texas Splash
33,620
Fiberglass
CircuPool RJ-45 Plus
With wide spread iron staining (confirmed by Vitamin C), you'll want to use the AA process below. Keep in mind that only pulls the stains off the liner and puts iron into a water solution form. Ideally you'll want to exchange the water to remove it. Or you can try filtering the iron through polyfill. I suspect you're on a well perhaps? That's a common source of iron.
Reactions: Suzanne81571
Texas Splash
33,620
Fiberglass
If you see your water change colors like this, that's an ideal time to filter out iron like in the pic below. Iron also reacts when the pH and/or FC levels get too high, so be careful about those as well.
YippeeSkippy
17,628
Evans, Georgia
Do you fill from a well?
This is my favorite Iron in the water thread.... read it and see if you can adapt it to your pool. It works well!
Maddie :flower:
Suzanne81571
15
Eastern PA
Thank you all for your responses. They was very informative. No, we don't have a well. We did notice rust on the skimmer bolts when we opened the pool this year. The rust never happened until this year.
Can I purchase polyfill and Absorbic Acid at the pool store?
Suzanne
Texas Splash
33,620
Fiberglass
Best to get the AA online. You could probably get the polyfill online as well, although I'm sure various local department and fabric stores probably have the poly as we. Event though you aren't on a well, there's no doubt you have an elevated iron content coming from somewhere. It would be ideal to pinpoint the source. Don't rule out city water. Check you annual water report for iron levels. Normally toilets and such will stain quickly. You could grab a water sample from the garden hose and get a free store test. No need to tell them where you got the water, just smile and say thank you. :) Some old plumbing in teh US had steel, so that's another possibility that might apply.
