Metal in pool
gasman1223
12
Rhode Island
Hello I have a well and there is metals in it about 4 weeks ago I put in 4 inches well water in my pool. Pool is about 14,000 gallons. I put metal out 3 different times and 1 pouch culator each time it pulls the metal out then it comes back. I know it reacts to the chlorine.This week Sunday night I put in the regular amount of chlorine Pool stayed blue. Monday night regular amount of chlorine pool stayed blue.Tuesday night regular amount of chlorine pool stayed blue. This morning Wednesday pool blue.turned on pump 3 hours later green. I can see rusty metal where my skimmer attaches to the wall of the pool. Do you think my problem is coming from the wall of the pool where it is rusty.
Texas Splash
Welcome to TFP! :wave: Once iron is in the water, you either have to filter it out or replace water. Sequestrant only keep the iron in water solution. You might try the process listed in the link below. It worked well for them.
gasman1223
12
Rhode Island
I have filter it with cotton rags every day every time I put a metal treatment in rag turn brown. Do you think the rusty wall that you can see in the water through the skimmer basket is causing the metals
mguzzy
2,039
OV, CA
GasMan! love the name... When you use a sequestrant it ties the metal up chemically, but it doesn't "remove it" from the water. Eventually the sequestrant will break down and releases the metal back into the water. As Splash explained the only way to get rid of it is by filtering it out or with a water exchange. If you are filling your pool with well water from evaporation, then you are just always adding metals to the pool. Its a fact of life with a well.
Your description sounds like pretty classic Iron.. we look forward to your pics.
ALSO! Welcome to the forum. it would be great if you could fill out your signature so we know what kind of equipment you have, it may have a bearing in what the forum guys recommend.
Texas Splash
Wow. No doubt you have an elevated iron level based on what you've filter so far. I would be surprised if the skimmer alone is responsible for the entire pool's elevated iron level, but it's certainly not helping. Have you checked you annual water report for iron levels? I would try to replace that skimmer piece and continue with the filtering. Each week is positive progress. :goodjob:
mguzzy
2,039
OV, CA
Can the rust at the skimmer change the water green when I put in Chlorine
Is there something rusting on the skimmer or is that metal staining? You can remove it with ascorbic acid (vitamin C) if its just a stain. Your rag looks like you have a LOT of iron. And if your pool is alternating creme de menthe green on the fly with chlorine you are seeing the effect of the iron coming out of solution. pretty wild huh?
I am dealing with an iron issue right now myself from tainted pool salt, and I'm using polyfill for the filter. I have the guts of 10,000 stuffed animals (thanks to my dogs) in the skimmer basket . so far its filtering it out, but I'll be interested to see how long it takes.
BTW can you fill in your signature so we can see at a glance what kind of pool and equipment you have. Make sure you include that you are on a well water. thx
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
34,052
That little bit of rust (already oxidized to boot is NOT your problem. Your problem is dissolved iron in your well water.
Do you have a water softener in your house?
