Mesh Cover for a 13x25 Above-Ground Rectangle Pool
May 23, 2009
1
Coppell, TX
I'm looking for a mesh cover for a 13x25 above-ground rectangle pool
My pool is a Laguna, I think
Would an oversized oval work?
Looking at online pool stores they only have 'above-ground' covers in oval
Above-ground covers look like a ratchet cable would help secure it
There are 'in-ground' rectangular covers, but they seem to be designed to be held down by water bags
I had a rectangle cover that I bought a long time ago and it finally wore out, I'd secured it to the support legs with bungie cords
Any recommendations? I want to try the ratchet cable to see if it does a better job of securing the cover
I live in the Dallas area, so; we do get freezing weather, but not a lot of snow
I've attached a picture of my pool
Thanks
Mdragger88
7,671
Hernando, Ms
Intex Krystal Clear
That is an intex pool - they make their own kind of solid covers that fit exactly . All of mine have come with them.
Although any other cover that fits would work. You would need it to be oversized if u went with oval to make up for the corners. When i had an intex style I bought enough ratchet straps to go all the way around the pool to secure the factory solid cover since it only came with a drawstring. Is there a reason you want a mesh vs solid?
