"Hello,
I’m in the planning stages for an inground pool with a SWG. Should I order steel or polymer pool panels?
Are the polymer panels a necessity for a saltwater pool? Would they last longer than the steel panels?
Thanks Joe"
@jimmythegreek this is up your alley and in your neighborhood.
(answer from @jimmythegreek)
"We quit using steel walls years ago. Steel will rust that is a given. Polymer won't rust. I wouldn't put a steel wall up and know that I am going to use salt chlorination.
steel walls are easier and faster for a DIYer as they are true and straight. if you have any groundwater issues you are better off with composite walls. depends on the kit brand some are really true and straight and others need some fudge work. Steel wall pools last decades in normal use, and with maintenence and no leaks will not eat up the steel any faster than a saltwater pool. after a few years of chlorine use your average pool has the same salt content as a saltwater pool anyways"
(question by OP)
"Hello,
Should the return and supply lines be buried in the cement collar around the pool or should they be plumbed on top of the collar?. I guess one of the benefits of submerging the plumbing in cement is it might prevent a leak. Not 100% sure on that one.
Joe"
Thanks Joe"
(question by OP)
"Hello,
Joe"
In ground, free form, vinyl.What kind of pool?
