Maytronics Dolphin dirty insides
Derekb
0
Jun 9, 2016
13
Merion Station PA
I just took a closer look at my Dolphin. It has seemed slow lately. I found that inside the side covers was full of leaves. Also under the treads the wheels were covered with almost mossy stuff; probably "mulched" leaves. I took the top cover off and blasted water down the sides of the cover. This is the part that you cannot get to without removing the top. I considered trying to remove the sides, but it looked like some sort of a snapped plastic connection I did not want to break it. After about 30 minutes of blasting water from both the top and the bottom, and using a curved pick to dig stuff out I finally got it all.
This seems like a design issue. Has anyone else experienced this and found a solution?
TIA
