Mastertemp 400 - Won't ignite
Justantru
18
Kaysville, Utah
Pentair Intellichlor IC-40
Hello,
My mastertemp 400 heater does not recycle and service heater light turns on immediately. The "High Limit Switch" error code is highlighted on the control board. Does this just mean I need to replace the high limit switch?
ajw22
28,644
Northern NJ
Pentair Intellichlor IC-60
Test the HLS continuity using a multimeter. If the HLS is open when the heater is cold then the switch fails and needs replacement.
Does it throw the HLS fault before the heater starts up?
Justantru
18
Kaysville, Utah
Yes. I order a new switch and will have it installed tomorrow. If that does not work, what is my next step?
ajw22
28,644
Northern NJ
See what error you get after you replace the HLS.
ajw22
28,644
Northern NJ
Justantru
18
Kaysville, Utah
Sorry to bother you, but I am still having problems. The heater is now working for a while, but cycles to service for 10 min or so then turns back on. It takes forever to heat the SPA. Thoughts on my next step?
