MasterTemp 400 making noises when starting up
thptrek
30
Houston, TX
When my MasterTemp starts up, the blower comes on, then it ignites but I hear a whole bunch of clicking and rattling noises. I notice that the inlet piping to the heating is shaking too. The ignition shuts down but then after about 15 seconds it fires back up and then it runs fine. I was thinking that it was a flow rate issue so I increased my VSF pump by 500 rpm. The pump flowrate says 43 gpm.
This cycle happens at every start. We did have the big freeze here and I am wondering if something inside broke like the bypass valve or such and that is the rattling noise I hear. It is strange that it seems to work on the second reignition. I have attached a link to a video I made so you can hear the sounds.
thptrek
30
Houston, TX
Bypass valve broken from the sounds. Had repairman out and in trying to remove bolts that hold the manifold, a bolt was all corroded and snapped off. Says he can’t get manifold off now to get to bypass valve and bolt goes into heat exchanger. Net result is at this, point need new heater.
ajw22
26,339
Northern NJ
Pentair Intellichlor IC-60
There are bolt extractors that can be tried to salvage it. It may work or it may not. The repairman probably figured it is not worth his time to spend hours trying to get the broken bolt out. I don't know how handy you are.
Post pics of the broken bolt area if you want more help.
@JamesW
Reactions: thptrek
imrodee
1,050
Waxahachie, TX
Pentair Intellichlor IC-40
Our insurance is covering any repairs over our deductible. Our adjuster told us to take pics and save the parts and receipts. Those heaters aren't cheap, especially hard when we already replaced the filter and main pump and the multiport system. ugh.. Good luck!
Reactions: thptrek
