Master Temp 125 heats a min then shuts down and shows AFS
AquaChic
In The Industry
Aug 20, 2021
1
Shreveport, La
I need help with a Master Temp 125 natural gas heater. It fires up and runs about a minute then shuts down and AFS lights up on the control board. I checked the gas pressure, it's good. I replaced the Air Flow Switch, Gas shut off sensor, Hi Limit sensor, thermistor, and thermo-regulator. It has a sand filter (TA100) and a 1hp FR whisperflo pump. I've backwashed and the sand isn't old. It has good prime so I don't believe it's a water flow issue. Now what???
ajw22
35,173
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
Check for nests in the mixer or burner areas…
1poolman1
In The Industry
Jul 14, 2014
1,562
Sacramento
The Mater Temp heater has a sealed combustion chamber. Usually, that issue is a failed internal bypass assembly allowing too much water to bypass the heat exchanger. I've done 3 this year alone. The manifold has to be removed and disassembled for that repair. While you're at it, replace the thermal regulator kit as well. When one goes the other is usually bad as well or will fail shortly and cause the same issue. Its worth the added expense.
