- Jan 24, 2020
- 72
- Plaster
I was browsing chlorinators, seeing what is available in the event mine dies in the future. In Australia, our SWGs typically have high salt requirements, but I noticed one brand claimed CH must be between 100 - 250 to avoid premature death. All other recommended chemistry parameters are aligned with TFP, which is refreshing.
My math suggests that this is a very bad idea, negative CSI would be to low.
Why would they recommend such a level? I paste the quote below:
HARDNESS
100 to 250 ppm. Levels higher than the recommended level will result in a less efficient cell in regards to its chlorine production, a more frequent need for cleaning, and a chance the cell will fail prematurely. To minimise chances of high hardness levels minimise or avoid the use of chemicals containing calcium, especially, "Calcium Hardness" and calcium-based granular chlorine.
HARDNESS
