I am thinking of trying to use this above ground pump/ filter combo to try and vacuum my pool without needing to hook up the the pools system. This should save a bunch of time as well as not closing up my actual pools cartridge filter.
Will this work?
Intex 28635EG Krystal Clear Cartridge Filter Pump for Above Ground Pools, 1500 GPH Pump Flow Rate, 110-120V with GFCI Amazon.com : Intex 28635EG Krystal Clear Cartridge Filter Pump for Above Ground Pools, 1500 GPH Pump Flow Rate, 110-120V with GFCI : Swimming Pool Water Pumps : Garden & Outdoor
Will this work?
