manual vacuuming question
Bperry
4,272
Knoxville, TN
CircuPool RJ-60
Guys
Is this ok to remove a skimmer basket when vacuuming a pool manually?
The reason i am asking this is because we don`t have standard vac plate here so what are your thoughts?
Thanks
I remove the skimmer basket and plug the vaccum directly into the skimmer port. Am I doing it wrong?
Reactions: amin36
Bperry
4,272
Knoxville, TN
CircuPool RJ-60
Thanks
You know some people say that vacuuming without a skimmer will cause the pump impeller to clog due to not using the skimmer basket to catch the debris and pump will overheat.
Is that true?
I don’t vacuum manually very often and wouldn’t use it to get large debris out so there may be some truth to that. I would use a robot or brush+net to get anything large out first before vacuuming.
Your pump should have its own basket though so I wouldn’t worry about the pump impeller. I’d be more worried (if I was worried at all) about getting debris stuck in the pipe leading to the pump.
Reactions: amin36
amin36
In The Industry
Nov 24, 2017
183
shahsavar
Here the diameter of the vac hose is about 4 centimeters(1.57 inches) while the diameter of the pipe leading to the pump is 6 centimeters(2.36 inches).so i don't think this is going to be a problem
Tcadwall0
207
Charlotte, NC
Fiberglass
Pentair Intellichlor IC-20
Reactions: amin36
