Making the plunge
midlifecrisis
68
Austin, TX
Okay folks, I’ve decided I’m going to make my brand new pool even better and go with a SWG!!! Although I’ve got Pentair automation, I’ve decided to go with CircuPool RJ-45 over the Pentair based solely on my ability to self-install while maintaining the full warrant, unless someone has a strong argument not too. I plan on buying the RJ-30 from discountsaltpool and use the $5 offer to go to the next size up!! I’m assuming that’s not too much overkill here or is it (5x my volume)?
As I think this through, I’m thinking I should be able to power it from my panel as a feature circuit and assign a timer for x time per day that will meet the minimum flow requirement (currently run pump 24/7 @1200 RPM). Is this a doable approach? Is there a better method, or am I wrong In my thinking.
im a bit excited about this project. Is something wrong with me?!?!
JoyfulNoise
Platinum Supporter
May 23, 2015
22,172
Pentair Intellichlor IC-60
If you have Pentair automation you should get an IC SWG. It will integrate with your automation seamlessly giving you the safety feature of not allowing the SWG to run unless the pump is running. This is an important feature. If you buy an IntelliChlor online with an “EC-xxxxx” part number, you are allowed to self install it and get the 2 year warranty.
Mdragger88
7,812
Hernando, Ms
Intex Krystal Clear
Not around here! You have found your tribe! 🤣
We’re excited for you!
Joining Welcome Home GIF
Jimrahbe
28,583
Bedford, TX
MLC,
Well, it is not what I would recommend, but it will work.
I have an EasyTouch and use the IntelliChlor IC40.. This allows me to adjust the cell from ScreenLogic. Not something you can do if you use the off brand cell.
If I did not have an EasyTouch I would use a CircuPool cell. But it does not make any sense to me to have an EasyTouch and not use an IntelliChlor Cell.
You get ScreenLogic pages like this one..
View media item 1963
You obviously need the Power Center and the cell.
midlifecrisis
68
Austin, TX
Thanks for the input, both of ya, I clearly missed the part somewhere of the two year warranty being available on self-installs with the Pentair and that does change things a bit, so I’m still in the market but am going to consider this new info.
I'm assuming, based on what’s posted here the IC-40 is a good bet for my small pool, providing plenty of breathing room without overworking it and helping maximize my investment?
Jimrahbe
28,583
Bedford, TX
MLC,
Let's see what Marty has to say.. Calling @mknauss
I am not sure about a new install being covered by the Pentair warranty. It is true that if you already have a Pentair SWCG system, that you can replace the old cell under warranty, I am just not sure about a completely new install. :scratch:
I never, ever base my purchases on the warranty. I used to run several non-pool related repair centers and know how warranties work.. The vast majority of sales never fail until long after any warranty has expired, or they fail within the first 30 days. A warranty is just a sales tool.
mknauss
52,245
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
As you can see, I have a 6000 gallon pool. With an IC 40. It works great for me. I replaced the cell late last year after 8 years with the first one. It had not completely died yet, but was acting up.
I agree that if you have a Pentair automation system, get an Intellichlor. Polytec Pools in Las Vegas has the full system (power center and IC40) for $1500.
midlifecrisis
68
Austin, TX
Thanks for the feedback on this guys. I’m traveling for work this week so I’m going to ponder all this. my Initial belief was there was no warranty at all if the Pentair was self installed, but now that there is a one to get me started, my thoughts have shifted back towards favoring the IC40 because it integrates seamlessly with the automation.
JoyfulNoise
Platinum Supporter
May 23, 2015
22,172
The IntelliChlor line (IC-20/40/60) are solid SWG’s with a long history of good performance. Their only Achilles Heel is the flow switch sometimes goes flaky and that’s where they’ve embedded a thermistor to read temperature for the on-board electronics. When that thermistor goes wonky, the unit reports wacky salinity readings. There’s simple work-around for it and replacing them is stupid-simple to do. It’s just a nuisance more than anything else and you’d think Pentair would attempt to change the design to improve it but … nope. Other than that, my IC-40 gave me 8 solid years of chlorine production with no hassle. I’m on an IC-60 now and it’s just come back to life from its winter slumber and the FC output is “smoking hot” … I need to adjust it down a bit. Anyway, the seemless integration with your automation is more than worth it.
