Maintaining FC
TammyGriffin
273
Hephzibah Ga
Ok so now that my pools is almost completely clear. I've been wondering about maintaining fc. How do i keep it at my target range of 5 to 7? Right now I'm testing twice daily. Morning and night . And added cl when needed. Is that typical? And also do i over shoot the cl addition to account for the daily loss or is that wasting cl? Maybe as time goes by I will learn the habits of my pool but right now I'm not sure how much fc I'm losing in a day. Seems like a lot like 4 or 5 a day. Does that sound right? Thanks you guys!
RonsPlc
1,003
Gaylesville, AL
I live in Alabama, and I found that I needed to bump my CYA to about 60 so that my daily FC drop was about 3-4 points per day.
Test once per day at the same time of day, and adjust your FC accordingly, and you will get the hang of it quickly.
beez74
60
Phoenix AZ
Seems like you are over thinking......the key is between 5-7 if it falls a little bit below for a day its not gonna hurt ya......I test every other day once and add chlorine on those days to put the levels at the top of my range to give me that room between adds. right now I am at half a gallon of chlorine every other day. there are days i'll add more to give me an extra day because going over wont hurt
TammyGriffin
273
Hephzibah Ga
So do you think I should raise my cya higher so I'm not losing as much?
TammyGriffin
273
Hephzibah Ga
I seem to be losing too much to skip a day testing or adding because I would be below my minimum
cavey00
10
Las Vegas
I'm glad this question came up because I just finished SLAMing and I was wondering how much FC was normal to be losing during the day. 4-5 seems about right what I was seeing too when I was gone for the day. Just did a quick calculation on how much that will cost to maintain using liquid and it's about $90 a month where I'm at. If that's the case, a SWG might be in my near future.
TammyGriffin
273
Hephzibah Ga
More like $180 a month for me. Using about 2 gallons a day
jmikeb
309
stillwater oklahoma
tammy
you should be able to get by on half that (assuming 10% chlorine) two gallons is 6.7ppm loss per day. i think under 4ppm is more inline
what is your cya?
RonsPlc
1,003
Gaylesville, AL
You could try 50 for your CYA, and see what it does for your FC consumption.
That is how I ended up at 60. (By playing with it)
Reactions: jmikeb
TammyGriffin
273
Hephzibah Ga
Yes I passed the overnight test and cc. I did stop slamming before my water was completely clear because I had been slamming for 3 weeks straight and scrubbed everything. And it was a brand new sand filter. I think at that point most would agree that it was a matter of filtering at that point. So it was a judgement call on my part before I went chlorine broke. Lol but I was right and it's continuously gotten more and more clear. It's almost cystsal clear now.
