Hi all,
I'm relatively new to pool ownership and had shared my initial pool renovation thread here (The Great Mistake (photo heavy!) ). The pool is gunite, ~22k gallons, built-in spa, ~30 years old. Now that the pool itself is in good shape, we're focusing on the equipment. The pool company we use for the renovations (new lines, skimmers, replaster, new deck, etc..) seemed to be having trouble consistently getting the filter pump and filter to run. It would hold pressure a little bit and the filter/pump would prime and work, then eventually water would stop sloshing around the top of the filter (Sand filter, BTW) and the pressure would hang out around 2 psi. The only equipment partially working is the filter and the main filter pump. The spa jets and the booster pumps are all dead. All of the equipment is original (except the heater), so we're taking 30-year-old sunken pad with cracked and patched PVC, rusted out pumps, 30" filter that is one big egg of exposed fiberglass, etc... The company has repeatedly said they pressure tested all of the new lines multiple times and they hold pressure just fine.
This week, I had a company working for the home warranty we purchased look at the equipment (see if we can get anything replaced under warranty). These guys seemed pretty good. Right away he moved to running the filter / pump off of the main drain which he said had 100% pressure and worked fine. He said when hooked up to the skimmers as it should be, he was seeing about 85% pressure and there was a minor leak. This was already a fair bit more information than I'd gotten from the main pool contractor, and using the main drain actually allowed for consistent running of the filter, pump and heater, so we could start to use the pool a bit.
I didn't think to ask the guy, but what does that actually mean, "running off the main drain", and what does that look like differently than running off the skimmers. Is that adjusting the multiport valve in a certain way? I'm wondering if I was looking at the equipment, how I would know if it was running off the main drain as opposed to the skimmers? I'm also concerned about the new skimmer lines.. If the pool renovation company is saying they hold pressure fine, could the multiport be bad (very possible), or some other connections to those lines be at fault?
