- Mar 12, 2021
- 49
- Vinyl
- Pentair Intellichlor IC-60
Got my new Active 60/M600 from Marina's and started using it and 1st and 2nd time it errored out and didn't finish either cycle, the error says something that it thought it was out of water. Third try it finally worked but didn't do a good job at all, left sediment along the corners of the bottom of the pool. Took over manual controls and tried to drive over the left over mess(fine particles sand like) it let me drive it some and noticed when I drove it forward it would lift itself off the bottom of the pool. Spent 20 mins trying to get a few spots then the robot shuts off and does not respond. Reset it and tried again and had the same problem. Got frustrated and pulled it out and cleaned it thoroughly. Last night I sent it on 2 cycles start of the night and early in the morning. Checked when I woke up it had completed both cycles but the pool still had that sediment. Tried the manual controls thinking maybe the robot had to break in and it would work but it had the same problem it shuts off after controlling for a few minutes. Tried calling Marina's during business hours a couple different times but no one answered. When I look at the app it shows a history tab and has a couple entries from 2018 with 600hrs and 700hrs of use with operational errors, did I get a refurbished robot? What am I doing wrong?
