- May 1, 2021
- 36
- Plaster
- CircuPool Edge-40
I installed a new Circupool edge 40 swg late summer and have had issues with it reading low salt (with 3600ppm salt), I believe because of scaling on the cell. After I clean the cell, it works fine. But I have had to clean scaling off the cell almost monthly. Doesn't sound normal.
My TA has hovered around 120. Test earlier today was 110. Water temp is unheated around 74.
CH 450
pH 7.8 (I typically lower pH to around 7.6 w/ MA when it gets near 8)
CYA 50
TC 9.5 (finally tapering down from high FC levels due to mustard algae 5-6wks ago).
My assumption to deal with SWG scaling is I need to get my 110 TA down. I Know about the drop pH + aeration method, but I'm wondering if just repeatedly dropping pH to 7.0 will also drop the TA over time?
CH 450
CYA 50
