Here's what I am seeing. I've had my pool for a little over a year now. My SWG worked great last year, in other words produced the amount of chlorine I would expect. This year it appears to be producing way less chlorine for the same run time. I didn't keep good track of what percentage I ran it at last year but I do remember when I had it at certain percentages my FC was going up day over day. This year even running at 85% I am losing chlorine day over day, and I have more CYA (40->70). I keep my chemical levels in check and am very diligent keeping the ph between the recommended levels to prevent scaling due to my hard water. I have not had any scaling that I can see on the salt cell (or anywhere else) but just to be sure I soaked it about a month ago in vinegar for an hour. My question is why would my SWG appear to be producing much less chlorine than it should be?
Here's a little background:
-Last year my CYA was around 40-50. This year I raised it to 70 as per the suggestions from TFP.
-I lose about 2 FC per day. I'm in sunny AZ.
-I have my SWG currently set to 85% and according to Pool Math that should produce 2.6 ppm FC. But last night I took a measurement and was at 2.5 FC and this morning I was at 4.5 FC which is only 2 FC produced.
Pump run times: 4 hours @ 3105 rpm + 4 hours @ 1725 (overnight) I've verified that the flow check is good at both speeds.
Salt cell diagnostic readings: 26.41V 5.03A 82F 3100ppm
My current values as of this morning.
FC: 4.5
CC: 0
ph: 7.8 (I usually lower to around 7.4 from 8.0 every week)
TA: 80
CH: 750 (we have hard water in AZ but since I control my chemical levels really well I do not have scaling issues)
CYA: 70
SALT: 3200
Temp: 82 F
CSI: 0.32
I've done some searching on the forum and haven't found much. A few of the related threads I have found but no concrete answers.
FC: 4.5
CC: 0
TA: 80
CYA: 70
SALT: 3200
Temp: 82 F
CSI: 0.32
SWG effectiveless seems less this year
I've had my RJ-30 SWG for about 16 months now. I've closely tracked water chemistry, chemical additions and SWG settings since the installation so I have good history. The SWG has served me well and was perhaps more effective than I expected, likely because of my screened pool enclosure. Very...
www.troublefreepool.com
Can SWG become less effective with age?
Our T-CELL-15 is on it's 5th year. I've noticed this year, it seemed like I need it on a lot longer to keep the same levels as last year - about twice as long. I had one error message last week to check the cell. I cleaned it out. Message went away for now. I also gave it the acid bath when I...
SWCG Reduced Efficiency as it Ages?
My SWCG seems to need to be on a higher percent this year to keep the pool at the same chlorine level as last year (7). I know the pool is clean it is not using any more chlorine, the SWG is just making less. Do SWCGs lose efficiency as they age? This is just the 3rd full year with it running...
