Low Salt Level - how bad is this
gigempools
3
Flower Mound, TX
Hello, I just recently converted to a salt pool. I had a salt cell installed (Jandy Pro Series TruClear). I initially put in 6 bags of salt. The salt cell was set to 100%. After 3 days I tested my chemicals and the Chlorine was a little high and my salt level was around 2100. I then reduced my salt cell to 50% and added 1 bag of salt. My chlorine level in normal now and the salt level is showing 2200. The pool is looking great still. How important is it that I get my salt level up to the recommended 3000-3400 level?
jark87
1,025
Flower Mound, TX
Jandy Aquapure 1400
My cell won’t produce chlorine if salt level is too low - below 2400 I think. Other than that, I don’t know the harm, but why risk it? Salt is cheap.
Reactions: Jimrahbe
Bperry
3,094
Knoxville, TN
CircuPool RJ-60
Are you sure the chlorine is high? Would be pretty hard for chlorine to be too high after only 3 days with a salt water chlorine generator. Make sure you follow the CYA/FC chart for the right level to make sure the water is sanitary. Here’s the chart: Chlorine / CYA Chart
generessler
470
Chapel Hill, North Carolina
Jandy Aquapure 1400
The manual for your cell is pretty clear. "Low salt concentration below 2,500 ppm will cause premature cell failure." Reading the book is a good idea, especially for something this expensive. The advice about getting a proper test kit is excellent. Salt sensors are far from perfect. If you adjust salt based on a false low reading, the result is too much salt. The only way to reduce it is to partially drain and replace.
Reactions: SR56
reggiehammond
937
Fort Worth, Texas
CircuPool RJ-60 Plus
I tested at my local Leslie Pool and I have a ORAPXI tester. Sounds like at a minimum it could result in the salt cell premature failure so it would be best that I go ahead and get it up to the correct level. Thanks everyone for the advice. Cheers!
My point on how you're testing is you don't know the precise level currently, and won't know what you've added. I highly suggest investing in the K-1766. It'll last many many seasons and serve you well.
There's numerous stories of people who trusted either pool store, cell reading, or digital testing and ended up adding too much salt, where the only solution is time and money (draining.)
Reactions: SR56
gigempools
3
Flower Mound, TX
Gotcha, I will order one now. Thank You!
