Low Pressure reading; also low salt reading
Tyrone Shuz
98
Bowie, MD
They may be related?
Pump and Skimmer baskets clear--no bubbles out of the return--I do the pressure gauge rotate--water comes out in about 1 second. Shut off the main drain still low pressure. There is a small occasional drip from the backwash line.
Aqua-Rite salt level reads 2300-2600--then I recalibrate doing the switch flip and it reads -3100. Drip tested and the lowest reading I got was 3200.
When pump was running 24/7 the salt readings were fine, but when I use the timer, I have to recalibrate every morning.
Is it possible my multi-port valve is malfunctioning and the low flow is messing with the SWG unit?
mknauss
51,246
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Does your SWCG completely power down when the pump is not running? It needs to be connected to the same timer as the pump.
