Low pH and high Alk
jbilliel
45
Connecticut
I opened my pool for the year and its been running for 2 weeks. It's crystal clear and ran all my tests this weekend, but not sure what the right approach should be to correct the pH without adding more Alk. Any thoughts?
pH - 6.6
Alk - 90
FC - 6.0
CA - 30
CH - 75
This is an above ground vinyl pool so I am not super concerned about the high alk, but if I add soda ash or baking soda with all add both pH and Alk.
pjt
1,012
The Woodlands, TX
Pentair Intellichlor IC-60
pH was measured with the TF100 Test Kit.
For the pH test in the TF-100, the bottom end of the scale is 6.8. How are you measuring 6.6?
How/why did the pH get that low?
With a TA of 90, your pH won't stay low for long. Aerate to speed up the pH rise.
