LOTS OF BACKSWIMMERS!!!!! HHHEEEEELLLLLPPPP!!!!!!!
Krazy1
10
i'm new to the whole pool scene :whoot: i have a 24'x52" intex pool. it has rained for three days here and afterwards me and the family were going swimming until we got to the pool. and to my suprise there was probably 30 or better backswimmers having the time of there lives in my pool :grrrr: there are also what looks to be egg pods floating in the water :| i am running an intex chlorine generator, and i don't have borates in my pool :roll: (yet) can someone please help me get this straightened out :cheers:
Krazy1
10
i'll get all the numbers when i go to lunch and post them up about 1:00
Thank you for the fast response!!!
Krazy1
10
0ok i went home, got hthe results:
Test strips
TH 70
TC between 0-1
FC 1
PH 7.2
TA 100
Stabilizer 10
Drop kit
CL 2.0
PH 7.6
Bama Rambler
23,046
Dude (or Dudette)! You seriously need a good test kit! Those numbers are seriously suspect.
You need to get your FC (free chlorine) up to around 5ppm if we can believe your CYA (stabilizer) number.
Bama Rambler
23,046
Click on the bottom link in my sig for the best darned test kit anywhere!
It seriously is the best kit. Once you get it we'll be able to give you much better advice because we'll know what the results really are. :)
Krazy1
10
can you recommend anything else to check the water with untill i can get some more money together?? :oops: i have spent myself out of spending on this pool for the current moment :hammer:
Bama Rambler
23,046
Walmart sells a 6-way HTH test kit that might do in the interim. Make sure it's the 6-way drop based kit. If it's not going to be very long before you have the money to get a good kit I'd save the money till I could get a good one.
Let us know what drop kit you're using and we might can make do for a while.
Kias
664
NW Ohio
Re: Re: LOTS OF BACKSWIMMERS!!!!! HHHEEEEELLLLLPPPP!!!!!!!
frustratedpoolmom said:
We need test results, a full set :)
Backswimmers tend to frequent pools where the water is not balanced properly.
I'm so going to concur. We filled our pool last weekend, it took 24 hours to fill with the garden hose. Within that 24 hours the pool gained well over a hundred backswimmers. Now that the water is balanced, well... My wife found one today. Probably a leftover.
Sent from my Droid using Tapatalk
clodda43
Active member
May 12, 2010
28
Bama Rambler said:
clodda -- Here you go.
They're smallish water bugs.
Thankfully I've not had a problem with water bugs!!! But last year towards the end of swimming season our pool was taken over by a bug that looked like a ant with cotton on it, and they had wings. Last fall we cut down the tree where they were coming from, so we are hoping that problem has been taken care.
Krazy1
10
i've got those too :roll: but the skimmer normally takes care of them :mrgreen: the backswimmers just don't DIE!!!!
poolgirl22
Platinum Supporter
595
Stephens City, VA
I get them every once in awhile. Less so this year than in past years. Now, the spiders that walk on water...those are my nemesis this year. It's the thing bad dreams are made of.
My daughter always called our one or two backswimmers....'swimmy'...so every year when one appears, we welcome old friend 'swimmy' and play with it in the leaf net.
Then I kill it when she isn't looking. :mrgreen:
Krazy1
10
right now i'm a cheapy and im using a 6-way strip kit, and a 3-way dropper kit.
im going to buy the TF100 in 2weeks
frustratedpoolmom
In The Industry
May 20, 2007
12,177
SWSuburban Chicago, IL
I assume your water is otherwise clear? So get your FC up according to the CYA chlorine chart, testing and adding it each evening. Do an overnight loss test. I suggest you add chlorine about 7-8 pm, and then at 10pm collect a sample. Test the FC level. Then test it again first thing in the morning before the sun hits the pool. If you are losing FC overnight, you'll need to shock the pool. You really need a good kit like the TF100 to shock properly. So in the meantime try to make due with what you have, and when you get your kit, post the results here and we can see where things are.
Keep us posted :)
Krazy1
10
that chart confuses the Crud out of me :| i'm makin it harder than it really is :roll:
i'll try and get it figured out. Thanks for all of the responses :shock:
i'll keep you posted.
Bama Rambler
23,046
Making it harder than it really is isn't hard to do with some of the things we use.
When looking at the chlorine/CYA chart you find your CYA level in the non-SWG chart and going across, the min level is the level you never want your FC to go below. The Target is what you want to enter in the pool calc so you'll add enough chlorine to get there. That way your FC won't drop below the min by the next evening when you test again.
Hmmm, that doesn't sound as clear as I hoped it would.
Other Threads of Interest
