Losing chlorine fast!
Leinbach
14
NE
Have a swg.My salt level is 2800. Can not keep chlorine level up. Last year I only added bleach about every other day. This year its every day. This morning there was zero chlorine in pool! Just added 89oz of bleach to bring it up to4. My cya is 80. Any thoughts?
mknauss
22,761
Laughlin, NV
How much chlorine can your SWCG generate in a day? How long are you running your SWCG each day? Do you have algae? What are your test results?
YippeeSkippy
11,813
Evans, Georgia
Can you give us a full set of test results?
FC
CC
pH
TA
CH
CYA
You may have a nascent algae bloom brewing.... ? How's your water look?
Are you testing your salt independently from the device? I never trust the device personally. How old is the cell? Could it need cleaning?
Maddie :flower:
Leinbach
14
NE
FC
CC
pH
TA
CH
CYA
Maddie :flower:
FC 4.5 after bleach
Cc 0
Ph 7.6
Ta 80
Cya 80
My swg doesn't give readings. Only shows if salt is to high/low. Been running it 9 hrs a day.
mknauss
22,761
Laughlin, NV
That is the Krystal Clear. In 9 hours, it can add 2.6 ppm FC to your pool each day. That is likely not enough this time of year. You either need to run the SWCG more each day or add liquid chlorine each day to make sure your keep the FC above the minimum as shown in FC/CYA Chart
Teald024
11 grams per hour is 9.3oz per day
9.3 oz per day in your 10700 gallons is 3.4ppm 6.5ppm of FC.
At 9 hours a day, that is less than 2.5ppm, 1.3ppm of FC.
Unfortunately that likely isn’t enough to replace the FC lost each day. Use liquid chlorine (bleach) to bring the FC up to 7ppm. Then run the SWG at 12 hours to see if you can maintain FC.
