Hi all,
First time pool owner, first year winterizing. TFP has been a great help with everything.
I'm confident the skimmer & main drain are winterized well, but the return line is making me nervous.
When I opened up this spring, I noticed owners (or pool store) drained below return line, and left it uncapped.
I didn't drain below return, & instead used shop vac to blow out from equipment pad & used one of the threaded plugs with an O-ring to cap it while it's bubbling.
On capping, it didn't look like it was leaking any air. To be "safe", I bought some RV antifreeze & filled the return line, again from the equipment pad.
The return line from the filter has some clear pipe where I can see the antifreeze -- see photos (inside filter & outside)
(Note: the 2 black pipes sticking out of the ground on the left side of this photo are just 'open' - I have no idea what they are for)
I figured "oh good, the pipe is filled with antifreeze"". Took about 1.5 jugs to fill it to this point.
Few days later, I check, the antifreeze is gone from the pipe.
I added some more, it took half a jug to get to the point where the visible pipe is filled w/ antifreeze.
Few days later, the same thing - antifreeze gone.
Same story, added a half jug, but this time I capped the filter drain plug & closed filter inlet jandy valve after.
Once again it is a few days later & antifreeze is gone from the visible pipe...
Any thoughts on a path forward? I'm not sure that I trust my winterization of the return line... Nor do I understand why I'm 'losing antifreeze' -- leak in the pipe, leak in the return cap, or something else?
Maybe I should just use my cover pump to drain the water below return lines & call it a day.
Thanks everyone. I appreciate any help, and If you have any questions let me know.
