looking for your pool bonding wire connection and i can't find it
Feneche
Active member
Jun 21, 2019
40
Las Vegas
The handrail should be bonded. You can connect the signal generator there and then scan around the entire perimeter of the equipment for the bond wire.
The #8 green wire is not the bond wire, but it should be connected to the bond wire. So, you can connect the signal generator to the #8 green wire and then scan around the entire perimeter of the equipment pad for a signal.
If you connect the signal generator to the #8 green wire, you should be able to detect a signal at the handrail. That will prove that the pool is bonded and that signal method works.
That a great idea i will order one right now
Thank you
