Have you been doing the CC portion of the fas-dpd chlorine test? That would have told you whether you have ammonia when you started.
Scratch the ammonia regimen comment. The last numbers you showed had CYA at 0.
You need to drain at least 40%. Be aware draining a vinyl liner pool has risk. Do not drain more than to the top of the bottom step in the shallow end. If you have high water tables in your area you may want to limit the drain to just 12-18" from the top. May need multiple drain/refills.
Take care.
You should switch where the pump/hose are. The pump should be at the bottom of the deep end and refill right at the surface, putting the hose in the skimmer works. The new water is less dense so it'll tend to stay at the surface of the water
