This winter when we opened our 27' above ground pool, we had some rust. Now that swimming is done, I would like to fix best I can. I plan to drain the water just below the skimmer and water inlet to paint.
What type of paint or product do you recommend?
Should I attempt to pull the liner back and look between the liner and the wall?
Is it safe to remove a top rail or two on the pool with the water only drained to slightly below the skimmer? Don't want the thing to blow out and flood!
thanks for any help!! If you have other suggestions please let me know! I know this thing won't last too much longer but would like to keep it best I can.
