I've been really thinking about pulling the trigger on a SWG system for my pool this season. Several SWG systems I've looked at have had notes about recommending only running the pump 10 hours/day or less to maximize the cell life. My pump is hardwired into a breaker panel with no control mechanism or timer, so I just let it run 24/7 unless I'm cleaning the filter cartridges or something. Does a great job keeping the surface skimmed too which is nice. Power here is cheap cheap cheap so I don't even notice it on the electric bill.
I was planning to run the salt system on a 120V outlet and depending on the system either set it to only run for certain amount of time, or even just put an inline timer between the system and the outlet to limit the actual runtime of the SWG. Will the moving water in the pipe over the cells even if they're off actually cause meaningful degradation of them?
