Hello,
I have a Dolphin S300i that works great to clean my 60'x11' lap pool. I'm trying to determine if there is a longer power cord available for the power supply. The cord that came with my cleaner is about 6 feet long, the connector that plugs into the power supply says "PHS-314" and the connector that plugs into power outlet says "PHP-301". The cord is made by a company called "PHINO".
I read on another web site that the Dolphin Commercial Robots have longer power supply power cords. Can anyone confirm this?
I'm wondering if I can obtain a longer Dolphin Commercial Robot power cord that will plug into/work with my S300i power supply.
The only thing that makes this cord special is that it has a big rubber square seal on the end that plugs into the power supply (presumably to keep water out of power supply in case of rain).
So a Dolphin Commercial Robot power cord would need to have a similar seal that would fit the S300i power supply.
I called my local Dolphin dealer where I purchased the S300i and he is going to call Dolphin tech support and ask this question, but I figured I'd also ask here in case anyone is familiar with the Dolphin Commercial Robots. I'll post a follow-up once I hear back from my dealer.
My reason for this - I have been running an extension cord to an outlet on the side of my house. I'm having a new outlet installed closer, but where I want it is a little further than 6' away. If I could get a somewhat longer power supply cord, then I could do away with the extension cord, which is much preferable.
Any info you could provide would be appreciated! Thank you!
