Little cloudy
Texas Splash
It's good you passed an OCLT, but remember that's only one of the SLAM criteria. Generally we don't even consider doing an OCLT unless the water is already crystal clear to the bottom. With a CYA of 70, your FC should be 28 (see FC/CYA Chart), so I'd continue with the SLAM Process until you achieve that crystal clear water, then verify the CC is less than .5 and run another Overnight Chlorine Loss Test.
