Literally can’t brush the algae of the edges
microscopes
115
Buffalo, NY
The pool was left alone for 2 weeks and grew quite a bit of algae.
The middle vacuumed pretty easy
However the edges are practically glued on. It’s like brushing concrete.
any advice? There is 3 gallons of 12.5% bleach in a 10,000 gallon pool so the FC is sky high already.
microscopes
115
Buffalo, NY
Also, the water is crystal clear. Not sure if that matters, but figured I’d add it.
I got into the pool in order to give a little more “oomph” to the brush, but that didn’t work. Hopefully being in the pool with the edges full of algae isn’t harmful?
Mdragger88
1,281
Hernando, Ms
Visible algae—->follow the SLAM Process to the letter.
Adhere to the FC/CYA Chart for your slam level- no more, no less (as it just wastes chlorine) Until u meet all 3 end of slam criteria.
It is Safe to be in the water between min & slam level fc so long as you can see the bottom of the pool. Algae isn’t gonna harm u . The main issue is that usually in an algae infested pool the chlorine is low (because algae is consuming it rapidly) & there’s not enough fc to prevent other nasties - if you’re maintaining sufficient chlorine levels its fine.
Your sig says u have an above ground pool- try a microfiber cloth on the liner - it takes time for consistent slam levels to kill algae.
what are your test results?
Fc
Cc
Cya?
microscopes
115
Buffalo, NY
Fc
Cc
Cya?
Chlorine - 30+
CYA -20 (I have more acid to put in)
Usually my whole pool turns green. Right now, the pool is crystal clear - I can see every “rock” on the vinyl liner. It’s just the edges of the pool and partially up the side thats algae.
Mdragger88
1,281
Hernando, Ms
There’s no reason to go so high w/ the fc - it doesn’t = faster progress .
You’re not slamming you’re nuking (not recommended) & wasting alot of bleach to the sun & possibly contributing to any scale.
your liner & equipment are paying the price
Let chlorine drop to 10 & run all the tests
