Liquid CL efficacy ques
tstex
1,869
Houston, TX
Hello to all,
I fill two 5 gal containers of 12.5% bleach and if I do not vent them by leaving the cap unscrewed just enough to allow excess gas to escape, then the plastic containers start to bulge. I keep them in the utility room and when someone shuts the door and the dryer is running, it accelerates the process bc it's warmer...so I've mandated no more door shutting...Either way, if the gas does escape, is the efficacy of the liquid CL compromised any? thanks
Justhereforthebugs
In The Industry
Sep 30, 2020
6
Maryland
You are going to lose hypochlorite, the active chlorine sanitizer, with time. As you pointed out, temperature will accelerate the decomposition.
One of the decomposition products is oxygen. I don't think leaving the cap loose is going to do you any favors in keeping the bleach concentration up. It might save you having to vent, but generally leaving the lid off any chemical is not ideal.
I imagine most bleach containers can easily withstand whatever pressure would be built or are not as air-tight as the containers you transferred to. I'd recommend just venting them occasionally. 🤷‍♀️
EDIT: If you're concerned about them bursting, I would just vent them. You're not going to lose bleach from the oxygen venting, you're gaining oxygen because you're losing bleach.
tstex
1,869
Houston, TX
Thanks guys...I have barely turned the caps just enough to allow a very small amt of venting. Of course this happens more when they are just filled and it's warmer too. I keep in our utility room so it's temp controlled and never gets too hot, like our garage would. I've also stated, "no closing the doors when the drying is running" so that helps too. Thanks again, tstex
