Liquid chlorine shortage
AshleyMann
23
Spokane, WA
We can't find liquid chlorine anywhere in our area (Washington State). We normally buy from Walmart but they're completely out of stock. In lieu of having liquid chlorine, what are our options? I've only ever used the TFP method to keep our pool balanced...
Leebo
Admin
9,712
Eastern Ohio
Give a look at the video on that page, it’ll help explain your options plus maybe you’ll luck out and somebody else will have found something in your area. Don’t forget to check places like farm or pool stores as many of them have chlorine in stock.
mknauss
29,688
Laughlin, NV
You cannot SLAM with trichlor.
Your CH is OK to use some cal hypo, but how much depends on what your fill water CH is and how much you add during the summer.
AshleyMann
23
Spokane, WA
Okay so found 6 gallons of liquid bleach in the back at Ace Hardware. Pool has been open for about a week but we haven't balanced it yet. Here are our numbers:
FC: 0.5
CC: 0
PH: 7.0
TA 110ppm
CH: 220ppm
CYA: 0
I'm wondering how I should go about balancing it using a combo of the liquid chlorine we have and the tablets. I'm hoping to get more liquid chlorine soon, but no telling if that's going to be possible or not. Do I 100% need to SLAM? It's been cold and rainy here, but there was a ton of dead algae we cleaned out from it being improperly closed last year. Did a sweet and vacuum today. Pool looking pretty blue despite all that. Getting our solar cover ready to put on as well.
AshleyMann
23
Spokane, WA
Pool is pretty clear, but there was definitely dead algae on the bottom. I'll try to do a slam with the liquid chlorine we have and then just try to maintain with the tabs I guess?
AshleyMann
23
Spokane, WA
Looked up our city water report and it's 218ppm from our hose. We have a solar cover so try not to add water much, but inevitably every week in a half or so we're filling it up a bit.
mknauss
29,688
Laughlin, NV
Well, you can use some cal hypo and see how it goes. As long as you can keep your pool water CH below 400 ppm, you do not need to do any extraordinary measures. Our pool water is nearly always above that so I have to manage TA and pH at a lower level to keep from scale.
