Liquid Chlorine and correct amount
brimis
1
nj
I installed a new liner last week, 18 round, 4ft. high pool. The levels are as follows, PH, 7.2, Free Chlorine 1.0, Alkalinity 120 and Stabilizer 50. I'm using test strips to test the water. I'm new to liquid chlorine, How much liquid chlorine should we add to the pool on a daily basis. Thank you.
Griswald
744
Hope Mills, NC
With stabilzer at over 100 (100 is all the test strips can even show, it could be 200 or 300). You will need a 55 gallon drum to start. You need a test kit and to get stabilizer down to a managable 30 or so.
