Liner tear around intake
RiscIt
7
Western Maine
So apparently I didn't lower the water level enough over the winter and snow and ice built up around the intake, weighted it down, and pulled it down so hard that it pulled out and tore the liner.
Is this salvageable? Any way to patch it? Picture attached. It's a 16'x48' Intex Ultraframe on a landscaped pad in the side of a hill. I can't seem to find a new 16' liner anywhere (looks like they don't make it anymore), and moving to a larger pool means a lot of expensive landscaping work to expand the pad, let alone the cost of the new pool. It may be a moot point as over the past 2 years we'e seen more and more of the fuzzy fibers fraying along to top of the edge railing, so I don't know how long that's going to last anyway.
Any advice is welcome.
Blacklisted
201
El Cajon CA
I think it might be salvageable, it looks like the gasket goes over the rip. I would use a patch that covers the whole hole inside and out and re-cut the hole for the eyeball. It's at least worth a shot. Good luck an keep us informed.
RiscIt
7
Western Maine
Thanks Blacklisted. With only one reply, however, we weren't all that confident. Found a Summer Waves Elite 16'x48" Premium Frame at walmart for $277. I'll retro fit our sand filter to it. Thanks again.
Reactions: Casey
Blacklisted
201
El Cajon CA
I would have no problem patching that. I had a nice 1-2" slice from a old metal security bars that I was using to keep my dogs from digging around my pool with. They pushed it into the pool wall and it sliced it. I patched inside and out and had no problems. You can always keep the liner if it will fit your new frame or keep everything if you have the space. Glad you are back on track for pool season.
RiscIt
7
Western Maine
Thanks. The fuzzy fibers fraying all along to top of the edge railing were concerning us as well. That helped make the decision too. Not sure what we'll do with it yet.
Blacklisted
201
El Cajon CA
Keep a good chunk of the old liner for repairs of the new one if needed. I kept like a 2'x1' section for patching when I got a new pool.
