I need some help. I have an IG inherited pool with attached spa. There are two lights in the pool, one in the spa. By the equipment pad there are three junction boxes for the lights- each box has a jacketed cable that must run to the lights. They are wired as such: white from the power panel- common to all three junctions boxes. Black- one black from the power panel is tied to two of the junction boxes (blacks). Similarly there is a red from the power panel common to two of the boxes (reds). Then a second black and red from the power panel common to one of the three boxes (again to the separate black and red) I can imagine the two pool lights are tied to one another- through two of the junction boxes, and the third junction box to the spa light. Nothing is connected to power, there is no low voltage transformer... Why would three lines (white, black red) plus a ground run to each light?
