ledge lounger?
WhiteWine
57
Orlando
@SyncLock I have about 15.5" of water on my shelf. Do you think the swimways would work on it with the holes drilled?
Do you know the height from the ground to the top of where your knees would go?
Also how deep the plastic is (~5").
Thanks
DaveHidalgo
12
New Orleans, LA
Thats on the deeper side of water depths for a shelf. For 15" of water you will find that many options will float because they dont have enough weight resistance once submerged. Ledge Lounger has something called a riser adapter that allows the chaise to sit higher in the water and not directly on the ledge so that the weight still keeps them in place.
