LED pool light
resco
4
Los Angeles/ CA
New pool owner here. I want to swap out my existing in ground pool light with a color changing LED one. Currently my existing light is a 500w and the new LED is only a 45w, will this require that the breaker at the electrical panel be downsized or should I leave it as is?
Thank.
avspin
0
208
Reno, NV
Fiberglass
Pentair Intellichlor IC-40
The breaker goes by amps not watts so you are fine. It's probably a 15 or 20 amp breaker now. If it's a dedicated breaker you will have extra amps. On mine I tapped my light breaker for some outdoor plugs since the light is rarely used.
Also it should be GCFI breaker. If not, put one in.
Reactions: resco and wgipe
wgipe
436
Fletcher, OH
Keep in mind that the breaker is there to see to it that the wire does not get overloaded and cause a fire. Because of that, breaker size should be matched to wire gauge (in the most common cases - as with anything, there are exceptions.
Generally speaking, a 20-amp breaker should host 12AWG wire, while a 15-amp breaker typically hosts 14AWG.
GFCI protection is to make sure you don’t touch something and become the best path to ground (at least for long).
Reactions: resco
avspin
0
208
Reno, NV
Fiberglass
Yes, I ran all 12ga for my cover & light lines knowing There was going to be more in the future.
Reactions: resco
