I now have an Easytouch system and am considering upgrading the pool and spa lights from incandescent to LED.
It seems I can fully replace the fixtures with IntelliBrite 5G fixtures or I may just be able to replace the bulbs.
I found the AmerBrite replacement bulb for the pool light, but didn’t see a spa size replacement bulb. Are there options for the spa bulb that are recommended?
if I replace just the bulbs, will everything operate the same as if I had replaced the whole fixture?
Also, currently both lights are on the same circuit. Will that present any complications? What would be involved in separating them to be controlled separately?
Thanks in advance!
Thanks in advance!
