Leaves staining pool liner
mn_
24
Kitchener, Ont
We have closed our pool for the winter and not covering it for the winter likely.
We have a lot of mature trees around the pool and seem to be staining the bottom. Is there anything we can do to get rid of the staining?
ajw22
18,172
Northern NJ
Chlorine will remove organic tannin staining from leaves. Once you open your pool in the Spring higher chlorine levels and spot application of chlorine should clear it up.
Reactions: mn_
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
33,887
Elevated chlorine will remove the stains (about double your normal level) but I wouldn't wait 'til Spring......I would do it now
